(The solution for the following question is some lines below, thanks .org)
Hi guys,
Well... i was very excited about the installation in my new Aprilia RSVR 1000. Finally this Saturday i tried with my girlfriend and i have been not able to do it rigth.
The components are the following:
Main Unit
Pemiremeter Sensor and
Universal "T" Connectors (2 to turn sigal, one to the tail and another to ground).
Once we plugged the components the last connection was the one to the battery (+). When we did, the alarm began to siren with the turn signals flashing BUT NOT THE TAIL LIGHT. I disconnected the preimeter sensor and tried again to plug again to the battery, but all the same. Began to siren while the turn signal flashed.
I verified the tail connection and seemed to be right.
Another things is that the remote gauge does not connect with the main unit. Des not appear the icon refered to be "in range" and the bike was without plastics and by my side.
I am sad about it, any suggestion apreciated, and thanks in advance.
<!--EDIT|Cya
Reason for Edit: "Already solved"|1111339500 -->
Hi guys,
Main Unit
<!--EDIT|Cya
