help with my 2002
drgheith
well here goes , picked up the bike with bolt ons basic power mods, headers exhaust, power comander.. Now my question is that since I owned the bick 9k is the max rpm i can rev to.. is that normal or is that due to the power band on pc... an when i do rev it out it throws the f1 code i tried to read it but everytime i pull over an jump the wires there is no code...
Check your crankshaft position sensor...try to check the F1 while is still running...
Rev limiter should kick around 10200-10500...if it is a high rpm issue most likely is a sensor pick up signal not getting to the ECU, poor connection or the ECU itself....
