jspin
i just finished installing my cycle-tek co2 shifter and i'm having problems with it. unless i installed something wrong, the regulator is WAY out of adjustment. the gauge on the regulator is at 800psi and doesn't seem to move when i turn the allen head on the regulator. i understand that once there is pressure in the line, i can't adjust it without bleeding the pressure off first, but i tried adjusting the regulator without pressure in the line. how fine is the adjustment on the regulator? i thought i was turning the pressure down by turning the allen head clockwise/IN but it didn't seem to do anything until it got to a certain point where it sounded like it suddenly went full open.
the regulator is certainly way off after i messed with it, so i'm afraid to try adjusting it any more without a little advice. thanks...
