I got my dremel all charged up. before i start cutting is there anyone that has done this before have any words of advice??? I did a search for this topic and came up empty. Thanks in advance...
Hey - I have a clear lens with the reflector removed if you want it... it is roughly done; your dremel could smoothe it out - or at least you could practice on it before you mess up your current lens...
Send me an addy and I will get it in the mail to you tomorrow...
What undertail are you installing? Most of them come with a completely new set of lights, so the factory bulb isn't an issue. If it maintains the stock light you will need to remove the reflector portion of the lens.
I have a cut Tiger Tail. I'm 2 inches lower and 6inches longer in the back now, Myrtle beach is coming up, I had someone on the back yesterday for the first time since the change and I was scraping..... so imma stiffen my shock and cut off the useless reflector.....
