I am trying to trouble shoot an issue on my bike.
It has a Velocity Stage 2 system.
While NOT under a load, it will rev fine, no real noticable breaking up or back firing (maybe a hint around 7K... just barely)
However, under a load, it flat falls on it's face around 6 - 7K rpm.
It will break-up and nose-dive.
With it on the stands I was monitoring the lights on the ECU.
The RED light stays on constantly when the bike is running.
The YELLOW light does not... it cycles between being on and off while reving the engine.
Is this normal?
Should the YELLOW light flicker / cycle through being on and off while the RED light stays on?
Thanks all.
Is this normal?
Thanks all.
