rekeene
I'm trying to find out which wire is the high beam wire in the wiring harness going to ecu...I looked at the wire near high beam and is yellow but didn't work when i tapped into the harness. Does anyone know exactly which wire is the high beam wire and where it is located? I'm hooking up the Scorpio i-900 to run off the headlight instead of turn signals. Thanks
