Hey guys,
It's been awhile since I've been on here.
PLEASE, I need some help.
I have an '02 Busa with starting problems:
The bike turns over slowly even with a new battery but will generally start with the new battery although a bit slower crank than one would expect.
The battery will show 13.8 volts when idling, +14 volts when giving throttle.
12.8 v after initial shutdown then settles around 12.5 v. Bike will start again better but after a few days of not riding loses cranking power.
Overall the bike never really spins over quickly so it's difficult to start.
Battery Tender light is green but bike will not turn over quickly. Tender goes from blinking red to green fairly quickly saying the battery is charged.
I've tried a few different batteries but ultimately none will last even when I've used the Tender on them.
When jumped from a car, the bike will spin quickly and fire right up (maybe I am killing the batteries but I shouldn't need to jump in the first place).
I've tried a few different batteries with initial starting "ok" but still not cranking quickly.
13.8 volts when idling.
12.8 after initial shut off and will settle around 12.5 (haven't checked this after sitting for more that an hour).
9 Volts when cranking but a drop off will occur because bike has a hard time starting.
There was another post where someone had a similar issue.
https://www.hayabusa.org/forum/general-bike-related-topics/128955-slow-crank-no-start.html
The response was this:
I tried the above. Having a volt meter with one lead on the Neg terminal and the other lead on the frame is producing 0.5 volts while cranking. That doesn't seem to be a big enough draw to cause slow cranking, or does it?
Someone else mentioned there might be a draw on the battery running a test light from (+) terminal of battery to the disconnected (-) terminal's wire to see if there is a draw.
When I place to + lead of ohmmeter to + side of battery it shows infinite resistance (a good thing). But when I reverse the leads (+ side of ohmmeter to neg terminal) I see a draw there is a s shown in the attached pic. Is this normal?
I have researched this for quite awhile but have not been able to find a solution. Someone also mentioned beefing up the power wires coming off of the battery worked for him but no factory motorcycle should need this.
Maybe someone can tell me more voltage or resistance values. I don't feel like putting a new battery in until I can fix the problem otherwise I'll kill it. I may also post on other forums if I can't figure it out here. Thanks for any help.
Another thing that folks rarely check is resistance through the ground system. A bad negative ground (where does it ground on the busa, on the engine? on the frame?) will show you good voltage readings, but offers resistance and eats up voltage (potential) when high current for the starter is flowing. To check this, put a volt meter between the negative terminal of the battery and someplace on the engine. You won't read any voltage with the key on but not running or the engine running, but you will see a voltage when the starter is cranking (high current through the resistance of the ground strap and it's connections at both battery and the frame or engine).
