streetfighter
i have just recently rebuilt my busa and it wont start every now and then it will start run for a second high rev up and stop
c23 is the fault that is coming up
the bike is a 2000 model
tre fitted
powercommander
boz full system
k&n filter
i put the little block off plates onn the engine
i blocked off the vacum valve on the air box
i blocked off the pipe that leads to the setup on the front of the engine that i took off when i replaced them with the block off plates
when i turn the ignition on at first it comes up fi light on display and the fi light flashes
i have no side stand switch on anymore
it turns over real good sounds like it just needs somthing easy to fix this
if you could help me i would be thankful to any one who can help me out
john
lc4gs@hotmail.com
tre fitted
powercommander
boz full system
k&n filter
john
lc4gs@hotmail.com
