AsleepAtTheTree
This is so weird, not even sure if this is a common problem or not for ANY bike
Clutch steels and fibers went out, bought new oem kit, changed them out, slave cylinder started leaking shortly after, bought rebuild kit for both master and slave, changed them out, took forever(a week) to bleed and get pressure(tried multiple methods) ended up filling the slave till the piston was almost out the housing, ss line and slave with syringe through bleed screw while its off the pushrod, stuck it back on and bled it through the upper ss line on the master....finally got presurre...ehhhh
Road it for a day, jus cruising around
No problems
Brother calls me out on his 14r, we make a pass...i lose lol....get to the end of the street
No pressure
So of coarse im thinking, well i jus rebuilt the clutch n all, maybe i didn't bleed it all the way
Pump, bleed
Pump, bleed
Pump, bleed some more...pressure is back
Make another pass...clutch is mush again
No leaks
Pump bleed again, again and again...presure
Now heres thw weird part, ridw back home jus cruising, no problem, ride it the rest of the week jus cruising, no problem
But...
Make Another hard full throttle pass
Instant Mushy clutch again smh
What the hell is going on man smh!!!!
No problems
No pressure
Pump, bleed
Pump, bleed
No leaks
But...
