Hi,
Long Time Lurker here (Hiya Blue Bayou)
Bike is a 2001 with the external fuel pump (so a 2000 really)
& 25,000 Miles (nearly)
So I Need Help Deciding If I should Fix or just cut my losses and break the bike ...Obviously I don't want to Do this But I cant afford to throw good money after a bad project.
Anyway this is what happened
Bike literally one day just lost compression on all cylinders
I was replacing external Fuel pump with an external pump and FPR...(Engine was Cold).. and thats all she wrote! She never fired again till gasket was changed
Local area Mechanics (20 mile radius) were confused so I couldnt get anyone to even look at her (honestly!)
a Compression test was as follows (approx as I lost paper I wrote it on)
(1) 37
(2) 60
(3) 150
(4) was about 37 PSI
A little oil in cylinders and (3) was about 168 PSI " I cant remember other figures"
Head and Base surfaces were all straight and true..no skimming needed....just really carefull cleaning.
Anyway I replaced head gasket with a standard size Cometic Gasket
Now I know now I should have changed head bolts BUT I used the old ones
and torqued to 37.5 LB
I couldnt see any obvious sign of failure on gasket (I know you cant allways see it)
As expected It was a job torquing head down (that was reasuring)
Bike fired up straight away after 2 rotations using the new Pump/FPR combo and ran really nice,(allthough too rich)
new PSI readings were
(1) 200
(2) 231
(3) 240
(4) 228
(teaspoon of oil in cylinders made no difference on readings)
Merrily set off to MOT station (Passed with flying colours)
after 20 Miles
and 3 stops/heat cycles #3 cylinder dropped PSI....bike ran but on only 3 cylinders
I tried retorquing the bolts But they were still set at 37.5lb
So (wrongly I know) torqued them a little more ....felt a few slips like a couple bolts stretched
now all cylinder PSI's are silly low again
Is this evidence the bolts are/were bad ?
Or am I just a Twit
my Question is
Does Any body reading this see an answer leaping off the page at them
Would you Fix her with new APE studs and obviously new gasket
Or
Strip Her and cry as Ebay swallows her up?
(1) 37
(2) 60
(3) 150
(1) 200
(2) 231
(3) 240
(4) 228
after 20 Miles
Or am I just a Twit
my Question is
Or
