hayabusapower09
Ok so i went all out and bought a motion pro sync tool , so i could do the obvious . It all seemed to go pretty well after figuring out how to make the adjustments to balance the throttle bodys, i thought i got them about as close as possible and reset the idle to 1100 checkking it aginst my pc3 not the dash tach and all seemed good right. untill i started up to take it for a ride and given its 50 degrees out , it hesitated like a 15 yearold in a stick shift. once i got it above like 2000 rpm seemed to clear up and pull hard , also once up to operating temp it helped a bit but , was still not right in off idle acceleration . could anyone shed some light on what ive done wrong , did i go to far or not enough on the vaccum what king of vaccum reading should i see at idle , could mine be to low or to high causing this problem . it was all fine untill i synced the t bodies , and it even seems to have good idle quality's ,and doesnt hesitate on free rev , just under normal driving conditions. btw my map really seems to suck does anyone have anything good for a 06 busa with full ackrapovic 4,2,1 , stock filter, and removed pair valve. i really appreciate any help guys thanks :1zhelp:
