Okay team, trying to help my sister out again. Without getting into the details of the situation she has several Harleys or custom bikes that I am trying to help her get rid of. There is a 1989 Road King that was starting just fine and I ran it for 10 or 15 minutes on several occasions. When I started to move it after sitting for several years it started fine and when I let the clutch out it hesitated a little but we started moving and then it died.
Now I can't get the bike to start, there is zero fire at the coil (which I replaced thinking that was the issue). I put a volt meter on the 3 pin connector to the coil and I get 5 volts, what should it be and if 12 V what might keep it from getting full voltage? The battery is brand new and shows 13 volts.
HELP
Cap
HELP
Cap
