The motor is stock bore, stock cams. It has the strongest 10mm studs you can put in a Busa, which are the ARPs. I'm not sure how this particular turbo rates in comparison to a Garrett, but I will say this: a Super 16 or a Super 20 will not run out the back door like a GT35 and make 38 pounds of boost. The Mitsubishi turbos tend to hit a brick wall just under 25 pounds, which seems to be their surge point. With that said, I know I could get at least 50 more horsies out of this thing, maybe even hit 500. All the customer wanted was 400 rear wheel, so that was as far as he would let us go . . .
