He has an old High Standard 12 gauge pump. He says he loads all shells in it & they stay where they should. However, when he chambers first shell, the rest all fall from the tube? Any ideas I can give him? Posted via Mobile Device
the magazine catch is bent or worn. probably need to take it to someone that has a little experience to fix it right. he can try it, call up brownells, and order a new catch/spring assembly.
Since it's old how long has it been since it was CLEANED PROPERLY ?
99% of problems I encountered on the range with folks who thought they had gun problems were actually just dirty !
Maybe some crud dried up in there from yrs of use preventing spring from popping catch out properly ?
If not as M_Ridgeway says Brownells or Numrich/GunPartsco has parts for it . Numrich specializes in old guns and has schematics on their site so you can see and order correct part .
But first buy a can of 'Gunscrubber' and spray the crap out of it !
Yes it should but most often ESP with shotguns people clean the barrel and bolt .
Rarely do they unscrew or disassemble mag tube and really clean every nook and cranny .
Q-Tips are you friend
Yep, like they said, he needs to clean it properly first, then inspect it for obvious broken parts.
If nothing found, then it's a prudent idea to take it to a gunsmith. I doubt if it will cost much to have
it repaired.
