Got-Busa?
That's a good question!
Something isn't right. I would say you were so far out front that when you did top out, you were already on the breaks before they could run you down. That or the guys you are racing aren't taking there bikes to the limit. Maybe they are scared of the speed and give up once you are a couple bikes ahead.
My guess....
Otherwise you need to just role on side by side (not racing) and then once your apponent tops out, continue on if you can. Otherwise you will max out your true speed and they will continue to pull away. If they have any lowered gearing like you, it will be even worse for them. They might not even be doing 165mph actual.
My guess....
