ResidentEvil
Easy you take the mount flat plate and the short stem with the rubber rings on it and put a screw through the flat plate into the short stem and put it in the stem hole done.Then put a 12volt cigarette lighter plug on the trunk and you can use the cord that came with the gps, just a few zip ties mounted under the tank and seat to the front,and done.Put a fuse on the battery side connection from the lighter plug ,you can now charge anything that uses 12 lighter plug ..cell phone....tire pump ..ect
I put STRONG velcro on the GPS and flat plate and it's GOOD !!!
and YES I used my T-Mobile cell phone charger to power my GPS I didn't need it anymore.If more pics are need I can take more detailed.
