Family,
I'm about to purchase a stage 1 RCC (kit with BOV and water/meth injection and HD clutch springs). Before that I am going to be having my motor out for a transmission (shift fork) issue so I figured now would be a good time to beef up the motor for turbo applications. This is what I'm planning:
1. Cylinder Studs
2. Heavy Duty Valve Springs
3. Stainless Steel valves
4. Turbo Pistons
5. Turbo rods
I am planning to run maximum 8 psi of boost.
My question(s) are:
1. With the above setup will I need to install a base spacer as well?
2. With the above setup what would be the potential maximum boost I could run?
3. Do turbo pistons lower compression making a base spacer unnecessary?
4. Are there any additional changes I should be doing?
Cheers!
1. Cylinder Studs
4. Turbo Pistons
5. Turbo rods
My question(s) are:
Cheers!
