Gen1 motor stock. Add some beef! direction's?
swerve1
Who hasn't considered going turbo no we cant afford that right now! Just wanted to beef it up a lil 200hp get rid of the new 20k cycles
ali123
Banned
a decent big bore/head and cams done from a reputable place isn't cheap.... and u must understand that 202mphbusa is motorcycle literate... he does all his own stuff.... I caution against doing all ure own work... unless ure 100 percent confident.....carpenter/knecum… these guys make good power...but they don't share secrets for free.....
ali123
Banned
turbo versus NA making similar power, and 200 hp might not get rid of a modded h2... turbo is the way of the future.... a turbo solves all ure problems... and for what its worth... I thought I was done for when I had problems with my HIGHLY modded turbo bike... but in reality I haven't had to break out the credit card yet..... have a discussion with a real turbo builder.... a REAL talk.. u might be surprised..
202mphbusa
I'm building a 1397 now. Parts alone is into the $3k range and I've done all the work. While slightly cheaper than a turbo, I won't make the power a Stage 1 turbo will. All motor is expensive as is a turbo.
Complete build right? Piston kit and block swap from APE is like ~$900 with intake cam and gaskets/slotted sprockets you are looking at like 1200-1300
bang for buck those are the biggest gains
busakiller
Bike was tuned by a local tuner. He goes by hitman. He does a lot of bikes and has done a good amount of turbo bikes. The turbo bike traps 165 166 in 1/4 on 8 psi. Bike made 250 on 8psi with a shinko hook up after 5 hours on the dyno
greg3852
Gaskets and swap is around $1047. Head work will run around another $1000. Mine was more expensive but it is a better head. I used Web 395/378 cams with adjustable sprockets, so add another $1000
busakiller
You can find good deals on used stuff. Just make sure you know what your looking at. Or look for a motor that''s aleady built. I bought my 1397 all built. Some shop built it and couldn't sell the bike so they put stock motor in the bike and sold the motor separate. Take your time and look around
Thread starter Similar threads Forum Replies Date
Z stock motor gen1 times 1/4 Mile 4
Shifty41 Gen1 Busa - Turbo, Standalone, Built Motor - What else can I do? Turbo 37
Freechance Where can i buy a gen1 fan motor?? Busa problems 2
202mphbusa gen1 PMR clutch cover General Bike Related Topics 8
S Looking for chain slider for an 06 (gen1) busa Wanted 2
T Gen1 fuel pump. Wanted 22
H Hi , just wondering if anyone knows if a Gen1 Akrapovic Evolution full Titanium exhaust will fit a Gen2 k9? Gen II Busa Information 1
SSGT_B Rear Caliper Rebuild Gen1 Maintenance and Do-It-Yourself 9
ottafish Gen1 vs Gen2 Shifter arm / lever Gen II Busa Information 0
C Gen1 bussa power loss while riding ... General Bike Related Topics 2
mabupa Looking for cheap gen1 OEM mufflers Motor and Exhaust 2
I Gen1 99” dyno Dyno Kings 5
L Gen1 Mod Help in North TX? Electrical Mods 6
B Gen1 - stronger springs ? - additional "clip / bracket" recommended General Bike Related Topics 12
H Gen1 07 Busa problems 6
J San Diego Dyno tune Gen1 Dyno Kings 1
B Gen1 - Control Unit, ECU 16 bit / 32 bit - speed restriction - flashing Engine and Performance mods 16
SSGT_B Gen1 Clutch Mod or Not? Thoughts......... General Bike Related Topics 23
B Needle calibration GEN1 General Bike Related Topics 0
B Gen1 caliper measurements pleases. General Bike Related Topics 0
T Gen1 hayabusa lowering rear foot rest Busa Mods 8
J Gen1 clutch issues. Busa problems 2
R Gen1, need longer splined gear lever shaft Busa Mods 1
D Gen1 headlight assembly General Bike Related Topics 0
Neophyte Gen1 Gear Position Switch Testing Maintenance and Do-It-Yourself 11
Fastrong Got myself a K5 Gen1, things to do? New Owners Forum 4
Ryder601 Fairings gen1 for sale OEM $325 General Bike Related Topics 1
sportbikeryder Yosh Cams Stage 1 Gen1 Motor and Exhaust 29
jphillips Gen1 Hayabusa CRK Sensor Wire Colors Busa problems 1
R Gen1 Hayabusa tank bra General Bike Related Topics 6
R OK to use Gen2 regulator/rectifier in Gen1? General Bike Related Topics 6
kml Better drag coefficient gen1 or gen2 ? General Bike Related Topics 6
B sprocket dimensions for gen1 to fit dymag carbon wheels Track and Racing mods 6
K Gen 2 vs gen1 1397 Gen II Busa Information 34
P Gen1 Temp Gauge Busa problems 4
ali123 H2 gen1 vs gen2 General Bike Related Topics 25
ali123 Carrazzeria hayabusa gen1 wheel bearing? General Bike Related Topics 1
omc1984 Suspension Mods Gen1 General Bike Related Topics 72
ky busa Gen1 rolling with my gen2 General Bike Related Topics 13
GXR1147 Dynojet linear shift sensor (gen1) Turbo 21
Z-MAN74 Gen1 throttle body sync General Bike Related Topics 5
swerve1 Transmission gen 1 help! find or best for Gen1 and ...where Gen II Busa Information 20
s4060 13:1 Gen1 with tuned with PC3 General Bike Related Topics 0
Unklpunk New to me gen1 turbo Turbo 31
A Gen1 racebike modifications 1/4 Mile 10
henryace Gen 2 Ignition Switch Fit Gen1 Electrical Mods 2
Dscahill Gen1, Stage 1 Turbo 36
2 Gen1 Stator Issue Maintenance and Do-It-Yourself 5
djorgensen3 Difference Between Gen1 And Gen2 Tsukigi Cannon Exhaust General Bike Related Topics 6
Smokey74 Want To Break 200 Mph On Gen1 Top Speed 52
Similar threads
Latest Bikes
Forum statistics
Threads
174,579
Members
48,490
Latest member
HYABUSA717
