Draco1340
I've been away from the org for the while while the bike has been sitting lonely in the trailer all season. Time to tear her open for the first time and build her up. Since I've been away for a while, I was hoping to get a couple of questions answered.
1st - The Gen II has a smaller 18 mm wrist pin located higher up in the piston to accommodate the longer stroke. Has anyone felt this to be a design flaw at the 300 HP level. Are folks converting back to the 20 mm wrist pin and accomidating for the longer stroke with spacer under the block. If I need to change pistons and rods, should I stay with the Gen II setup or not?
2nd - I need to change Pistons, which means I need to bore the block. Several years ago, the turbo guys were complaining that the Gen II blocks were cracking. I don't recall what power level this was happening at, or if this was only at the 84 or 85 mm bore. I would be happy with 83 mm, but again plan on putting down around 300 at the tire on dope. Do I need to track down a Gen I block? What is the basic difference between the two generations of blocks?
3rd - this may cause some controversy among the vendors, but is there any known issues people are having with pistons or rod manufacturers. I just built a freind of mine's ZX14 motor this past weekend with Wossner pistons and Carillo's. Nice looking parts, although I thought the valve pockets and features on the pistons were razor sharp and needed breaking and polishing.
4th - What seems to be the limit the stock rods can take assuming no detonation. I log every pass, and make fuel adjustments as necessary, so I don't typically detonate even though I do run dope.
Thanks for your help.
