Gen II Gauge problem - Coolant temp full hot, CHEC, no Gear Position Info, no codes
V8Pinto
Having some trouble with my gauges and could use some help troubleshooting.
The symptoms are identical to if the key was on with the kill switch in the off position. When turning the key on, the gauges complete self test (full sweeps of all instruments), then the temp gauge goes to full-hot. The CHEC is lit with or without the jumper installed. The jumper does not produce any engine codes. No gear position information. All other features work and the bike starts and runs fine.
I have confirmed that the gauges are getting 12V continuous for the clock and also switched 12V (orange/green stripe wire). The ground at the gauges is also good. I have swapped in another set of gauges that showed the same symptoms. Also, I have used another wiring harness with the same results. I have also checked another ECU that does the same thing. I have tried this with a MoTec, a Bazzaz, and removed both and tried just the factory harness and ECU.
I have a 2Ga ground cable going to the engine with the stock ground wire running to the ECU. I've ohmed this out and it looks good. I also ohmed from the battery/chassis ground to the gauge ground and it shows as less than an ohm so the ground looks good.
Last night I ran ground and 12V to both 12V pins on the gauges without any other connections and it shows same results (removing the harness from the equation).
Any suggestions?
Big E
Re: Gen II Gauge problem - Coolant temp full hot, CHEC, no Gear Position Info, no cod
Have ya recently installed HIDs?
V8Pinto
No HID's installed.
Getn off
Is there an external temp sensor on this bike? If so, maybe faulty pushing a high reading? Good luck.
Troy
Quiksilver
If my bike is key on and kill switch off (or in gear?) The check stays lit and the temp I'll way up. Flip the switch to run and everything goes to normal.
I'm not sure about Gen 2 though.
V8Pinto
Troy
No external temp sensor and I've run the temp sensor through the ohms test (10 ohms to 140something as spelled out in the manual) with no luck. The gauge is not active. I think the ECU needs to send it input to sweep it.
When the engine is running, I can plug and unplug the coolant temp sensor and hear the revs change so I know the ECU is seeing the coolant temp sensor but it's not updating the gauge.
V8Pinto
Yes this is exactly what happens but I've traced the switched 12V to everywhere it goes and it is working. Orange with white wire, activates the fuel pump relay and primes the pump like it should, engine runs (or shuts off) with the kill switch - just no temp gauge or fault code readings. No odometer either.
Gallier1975
Any suggestions?
V8pinto did you ever find out the issues you had with these problems.i have same issues with same year
Dopey
That post was the last time he was here so don't expect him to answer, don't really understand his issue because it seems he was never starting the bike but I do know that's how the cluster is supposed to function until it's started and then the gauge will drop
Gallier1975
My gauge works fine until i ride it .every 5seconds it does the self check sweep and all gauges go back to normal but again self check again.bikes rides great.did dealer more and pulled c36 c37 c38 secondary injector codes and c40 and c62 evap purge .going to worl on it this week and see what i can come up with.thank yor for the response
Latest Bikes
  • Hayabusa Addict
    From back to front; 2014 9.99 index champion 2005 all motor class...
    • Motonutz916
    • Updated:
  • My Gen 3 Busa
    Photos of my 10 year freshen up on my 2009 Hayabusa. Parts highlights...
    • fallenarch
    • Updated:
  • Art 05 Hayabusa
    hayabusa 05
    • VIPER
    • Updated:
  • toads L2
    L2 as it is ridden today
    • ROADTOAD1340
    • Updated:
  • Busa in another part of Cornwall
    Cotehele pretty spot but residents didn't appreciate the Busa. I guess...
    • Grumpyoldjohn
    • Updated:
Forum statistics
Threads
172,570
Members
47,558
Latest member
DjDaxBoogie
