3WheelerMod
So I continue to battle my BUSA. I am currently using a 2006 Busa as the engine in my Trex-copy 3 wheeler. I have been working on this for a couple of years dealing with all sorts of things. The last thing I had to figure out was the shifting mechanism. All the while I have been (periodically) starting the bike. I have had to prime it a few times with starting fluid but always started.
She is ready to run... inaugural voyage .... and .... turns over but won't start.
Here is what I have done so far:
1. Replaced spark plugs
2. Replaced Throttle position sensor (From Ebay)
3. Replaced the temp sensor (From Ebay)
4. Replaced voltage regulator (From Ebay)
5. New battery (Marine battery due to all the different lights etc. I have on the 3 wheeler)
6. Tip over sensor - glued so it does not move
When I put it in dealer mode, I do not get any "F" error codes. I do get the standard COO code with the indicator line at the top instead of the middle.(you are suppose to adjust the throttle position sensor when it is warm... hard to do that when it won't run) But I am assuming this alone would not keep the bike from starting.
Just seems like I am not getting spark. I have been told that there is a ground issue with Gen I BUSA'S and this could cause problems??? However; my ground comes directly from my battery.
Any thoughts?
BTW... I hear my fuel pump...
Dying to get this thing on the road !!!
Todd
Any thoughts?
Todd
