no1sun
So, my 08 busa sailed through the MOT, but when I went to pick it up the clutch went harder and harder with every pull until it it went solid. Gets the bike back to the garage with the help of a van. Dismantled the sprocket cover and removed the slave clutch to find that apart from a fair bit of gunge the piston is solid. Plugged the banjo hole and tried to hand pump out the piston via the bleed screw with a hand bleeding syringe but nothing. I know it’s not much pressure. Used an easy-out on the push rod hole but won’t shift. Going to try compressed air tomorrow, hopefully. Has anyone had any similar problems and am I better just getting a new cylinder. Had a look on fleabay but nothing. I am based in a Kirkcaldy, Scotland. Any advice gladly received. Cheers Dave
