gen 2 lowering issues "need advice"
DANGER10R
This is the scenario,just put a macintosh swingarm on my 09 with brocks fully adjustable window links,you have no adjustment with these because all the way tightened in the tailight is damn near sitting on the tire WTF??Im gonna put my bike at 64"" and tighten my shock up some but im starting to think i should of just got the three hole no adjustment links cuz if i adjust these any my tailight will be resting on my tire.Anybody sitting at 64" have any remedies for not scraping chime in????IM 205 pounds and am wondering if i tighten everything up on my shock is it still gonna rub??
m_ridgeway
pipeline trash
did you go to the straight suspension link? dunno how long 64 is, but im 6 over, and 1.5 down in the rear, its rideable but rubs, no shock mods yet.
H2447INTX
ok your problem is this
thy offer two diff sets of lowering links, something like 3" and lower and then one that is close to stock and then you lower
i would have to guess you got the 3" drop and lower so even fully closed you are still sitting 3" lowe witch is low
you can see about returning them and getting the other set 0-3? i think any how look in to that
i have a ex swing arm with soupys ajustabel lowering links and i have no problem
im sitting about 1 in low in back and stock up front
any how look into the links you bought !
post some pics
fiend
Formerly fiend44444
The Brock's adjustable links at the highest setting is like being in the second hole on the 3hole lowering links. I am sittint at 63" and rubs if I ride 2up, tighten the shock up and it should help a little bit.
bigbadboy
im sitting at 65" and lowered in rear 2 maybe 2 1/2" . the front of course is slammed. you won't be able to ride to up but you can adjust your shock so it doesn't rub. im 200lbs and mine doesnt rub. the shock has abt 10mm of adjustability. i've got mine aprox. right in the middle at abt 5mm with the compression and rebound both set to the stiffest setting. it still rides good in the rear just a little more stiff (which i like). also you will find that as you adjust the shock it will raise the rear slightly........ which for me means not being able to touch both my feet on the ground :rofl:
H2447INTX
so what you are saying is you like it LONG LOW AND STIFF IN THE REAR ?:laugh:
got it !
i say get soupys!
and im still shocked that you all are slamming the front and that your not worried about the lowe tripple not contacting ?
Thread starter Similar threads Forum Replies Date
J Gen 2 lowering front Gen II Busa Information 11
A gen 2 busa lowering front end Gen II Busa Information 4
C Will a gen 2 lowering triple tree fit a gen 1? (searched) Busa Mods 3
A gen 2 busa triple trees lowering Gen II Busa Information 14
Hayabusa133 Lowering gen 2 hayabusa ??? Busa Mods 3
J gen 2 lowering links Busa Mods 2
bikerboy2182 What lowering triple clamp are u using???? gen 1 Appearance mods 4
Duke1340 Whats the best lowering links to get for my Gen II Gen II Busa Information 3
Duke1340 What is the best lowering links to get for my Gen II Gen II Busa Information 6
theshnizzle Lowering a Gen 2.... General Bike Related Topics 3
joebur Gen II Soupy Lowering Links ????? Busa Mods 7
S Lowering 2nd gen advice Gen II Busa Information 4
rubbersidedown Desperately needing a Gen II passenger seat Wanted 0
J First gen motor/clutch identification General Bike Related Topics 20
B R&g aero frame sliders gen 2 /1 same fitment ? Parts and Modifications 0
Kevin Jones Gen 2 GPS in a gen 1 Busa Mods 1
D Gen 2 Dashboard Gauges Stop Working Mid Ride Gen II Busa Information 3
RickyBobby Looking for Clutch Gen 1 Parts and Modifications 8
shade Gen 2 front fender OEM $90 Parts and Modifications 6
R Lenght of the piston of the front master cylinder gen 1 Busa problems 5
J Fi light c-28 code gen 2 issue Busa problems 15
Quiksilver Gen 2 cut seat Wanted 3
Z Oil change on Gen 2 2017 Maintenance and Do-It-Yourself 10
P Having trouble with my gen 2. Gen II Busa Information 26
Quiksilver Gen 2 backreat Trips and Touring 18
J Gen 1 fairing set options? Drop finished them off... Appearance mods 0
StreetShark Gen 2 idle issues Busa problems 11
T Gen 1 CHEC light no fuel prime or start - Fix Busa problems 0
J Gen 1 rear seat cowl led Parts and Modifications 1
Bigboy Busa2 Gen 1 grudge bike build. Racing Technical 25
Zukonda Ghost hose Gen 1?!?. Help!? Busa problems 16
J What all do I need to change to use a gen 1 swingarm on a gen 2? Gen II Busa Information 13
B Gen 1 ported head, after market cams, Pistons? Wanted 0
I Gen 1 running grumpy Busa problems 6
Sidebike Gen 1 Fairing Pieces For Sale on eBay. Parts and Modifications 1
B Smart tre gen 1 hayabusa General Bike Related Topics 1
M Gen 2 LEDS Gen II Busa Information 4
B Gen II Busa on Hwy 18 going UTH. Random Thoughts 3
M Gen 1 rear shock General Bike Related Topics 5
B Gen 1 hayabusa coil resistance General Bike Related Topics 6
B Can a Gen 1 keep up with newer bikes? General Bike Related Topics 46
P Adding digital speedometer to 2nd Gen Hayabusa General Bike Related Topics 5
P Gen 1 switchback lights General Bike Related Topics 1
E ISO gen 1 mirrors Appearance mods 5
9 Gen 2 full exhaust for sale Parts and Modifications 5
N Gen 2 service manual General Bike Related Topics 5
rubbersidedown Rubb looking for a Top case for Gen II Wanted 15
A Gen 2 wheel swap Busa Mods 0
Turbo Bob WTB Gen 2 Hump Or Base Wanted 5
CraigMcleod Gen 1 aluminium frame on gen 2 Gen II Busa Information 6
Similar threads
Latest Bikes
  • Bam Bam
    My Last Little Girl
    • rlmoorex
    • Updated:
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
Forum statistics
Threads
174,458
Members
48,432
Latest member
SumDumFuk
