KieranJ1992
Hello.
After purchasing a new chain and sprocket set, I have come to fit it and realised that my rear axel A.K.A spindle is siezed up.
I have tried whacking it several times, for hours, with a rubber mallet with rear paddock stand in use, wheel propped up, wheel on ground on side stand. You name it I have tried it, unless I am missing something obvious.
Can anyone please assist me as I've run out of ideas.
*I have sprayed a lot of lube on all possible areas.
Wheel does not seem to be buckled and everything else seems straight too.
I'm an all weather rider so I can assume the harsh winter has took a major impact and badly siezed the spindle. Also note that the spindle does look rather rusty*
Estimated 4k miles since wheel was last removed.
Thank you guys!
Edit* May I add that the spindle has not moved one bit since all I have tried above^*
Thank you guys!
