Gen 2 Center Stand Build For Touring .
c10
Well really a center JACK . ITs for a newer F150 truck . Modified with ZRX1200 rear axle cut down , and bolted to the factory exhaust rear hanger . I then used a old rear wheel spacer the axle fit to weld to the jack's upper plate . Now I plan on adding additional width to the jacks base ( about 2 " each side but it is pretty good now . Enough so to walk away for pictures , and spin the wheel . Can also piviot backwards to raise front wheel if needed .
I sure wish I had a factory stand like the gen 1 guys .
