It’s a 12.5:1cr.
4lbs of Boost is always advertised, but it’s usually 5-5.5psi when it’s all said and done. You never get exactly what spring pressure is rated for.
You can certainly get around the the high compression factor with enough octane, but the valve springs definitely are the biggest hold up. I want to say they’re like 20lb seat pressure or right around there.
This is one thing I’ll be playing with on the shop bike Lucy. I’ve always been curious how far they can be pushed. Typically when you get valve float you’ll see waves in the dyno readout, followed by a steady decline in power.
I’ve shown that on a stock gen 2 and “4psi” (5.5psi) you can make 280whp on e98. I’m going to try raising the boost to 7-7.5psi on Lucy on some gas station e85 and see if it makes 300hp or better. Lately the station by the shop has been pumping a consistent E75, so that should give me just enough head room with the stock injectors.
It will be exciting to see the results.
