GSX-R//Iceland
I had the unfortune of going down during an 1/8mile event, went down at about 120mph so the bike skid a fair bit on the pavement. Stator cover was ruined(replaced that), clutch lever broke(replaced it), rearsubframe broke and ofcourse the fairings were completely ruined on one side.
I cant seem to figure out what the problem is, the gauge cluster and all lights work when you turn the key but the fuel and heat gauges both show max when you turn the ignition on and the bike is not running. The check light is on. The fuel pump is not priming and the starter button does nothing. I have a pc3 usb and it does not receive power either when i turn the key.
so for ive tried to go over all the wires, checked the 8 fuses that or on the leftside by the ramair. Took the Tip over sensor apart and checked it(looks like its working), tried to go over the clutch lever and the sensor there. The kickstand sensor doesnt look damaged.
very frustrating that i cant seem to find what is wrong. Any suggestions welcome
Thanks in advance
Thanks in advance
