HybridConceptz
Hello everyone, this tutorial is meant for Generation 1 Hayabusa owners who would like to change the LED backlight to their gauges.
Items Required:
Small Phillips screwdriver
Regular Phillips screwdriver
Thin small flathead
Soldering Iron
De-soldering wick
Solder
8MM socket wrench
Metric Allen Set
29 - PLCC-2 LED'S (I would suggest buying these on ebay in a 50 count package as you wil lmost likely damage some or lose some)
LED REQUIRED FOR FIRST GEN ONLY!!!!!! SECOND GEN REQUIRES A DIFFERENT STYLE LED!!!!
Foreward - This project is not super difficult but is also not for the faint of heart, you will be pulling your gauges apart and you do have the possibility to damage the board beyond repair. The LED's are incredibly small and some people may need to use a magnifying glass to be able to see properly.
Items Required:
Thin small flathead
Soldering Iron
De-soldering wick
Solder
8MM socket wrench
Metric Allen Set
