My GiPro took me less than 10 minutes to install. I would make sure itcomes with the extran 20 dollar harnes to make it all plug an play. Programing is easy a pie.
Acumen digi gear just plugs into th back of the guages. theres only one connection takes less than 2 minutes to install. the hardest part is taking the top panels off you can get everything done in less than 5 minutes.
Wiring wise the one I do is very easy, just plug it into the euro connector, but requires installing a modified gps sensor.
I also do a gear indicator with build in launch and shift light using tri color LEDs and autoshift output as an option for guys with air shifters already.
its different, not everyone likes the 6 LED layout, but they work well and you get a TRE out of it as well.
