Gear indicator!!
07vigorblue
When i had my ecu reflashed for nitrous we turned off the speed limiter. I took the TRE off the bike since i no longer needed it and now the dear indicator only reads 1-5 is it supposed to do that. i may also need to reprogram because of the gear change but i dont think that would make a difference. I have a Data Tool indicator
PrObably cause it was flashed, cause with the gipro gear indicator the stock only shows 5 for the map it's set to. My guess anyhow.
