lifguardct
I have a locked gas cap on a good used tank. I need to remove the lock without damging the tank. I don't care about the lock. I was going to try to pull the lock cylinder with a slide hammer but thought I would check here first.
Also on the Fuel pump, is there a gasket or ? I need to switch the pump from the old tank to the good one.
