50 will be way too high and you will run rich for sure; 40 has worked fine for me, but I try to keep her at stock 42PSI...(Jibit @ Jul. 26 2007,02:42) right now I'm around 40 at idle. I've been told up towards 50 at idle and 80 at boost. Mechanic told me he seen as low as 30 (which is stupid to me but what do I know)
My fuel pressure is at 36psi at idle and 90-100 at wot, I have stock injectors and I have had my bike tuned by 3 tuners. If you followed the history of my build, you would understand why I had it retuned that many times. Anyway according to my last 2 tuners (which I trust), the lower idle pressure is easier to manage for tuning and I haven't noticed any ill effects because of it in ridability.
Should be at 42 PSI if you are using stock injectors or secondaries. If you are using S2000, the fuel preassure is quite a bit lower and I just can't remember how mcuh it was, but could find out quick if that is your setup...
You change the fuel preassure by adjusting the fuel regulator. Loosen nut on regulator and use alan to turn right to increase preassure, left to decrease preassure...
turning the screw in raises the pressure out lowers it
