Can the regulator be placed inline on the fuel supply between the pump and injector rails, bleeding pressure off through the return port?
Is it better to have it set up as a side stream, meaning a T in the supply line, with it located on the open end of the T off the supply, blowing down extra supply fuel pressure through the return port to the tank
Has anyone had any first hand experience with both ?
I ask , as it would be much easier for me to run the supply through the regulator due to space constraints, wheras the T in the supply with the regulator bleeding down pressure as a side stream takes up alot of space and extra fittings I really don't have room for method
How will it react if put inline?
Oh yeah, its an Aeromotive 1:1 referenced regulator BTW,
Thanks,
Lyle
Thanks,
Lyle
