If I drain my tank by removing one of the hoses under it will I have to re-presurize the system??? If so how do you do this? Or what would be the easyest way to drain the fuel from a disassembled Busa?
The fuel pump pressurises the system. Next time you turn the ignition on before starting listen carefully you'll hear the pump pressurising the system.
Look on the rear inner fender there are two plugs to put on tank when off. Make sure you pinch together line being taken off first so fuel will not back feed....just in case you have not got your shop manual yet...hope this helps.
