It's not a choke lever. It just keeps the throttle opened a crack (0.1 mm) more than at idle, thus giving you fast idle at startup. Nothing more.
Lift the tank, look where the "choke" cable goes, play with it a bit, and you will see how it works, and the screw which lets you adjust it.
Some folks adjust it in such a way that it fast idles at pretty high rpms (like 4000), and then use the fast idle to cruise at highway speeds. That's the cheapest cruise control mod available.
__
Igor
<span style='font-size:17pt;line-height:100%'>
<span style='color:darkred'>HumpMod.com</span> <span style='color:darkred'>- The easy way</span></span>
