Fuel gauge not working!
von1985
Hello there my 99 Busa gas needle doesn't work neither does the light, so I have been going to gas stations repeatedly. Would this be the fuel sending unit in the gas tank or the cluster because I replaced the external fuel pump already and come to think about it my neutral light doesn't work on the cluster either, but I can deal with that
1bondoman
raise the tank,unplug the smaller plug for the gauge,,use an ohm meter and check resistance,if there is no continuity then the sending unit is bad.
dadofthree
Seasoned Beef
If that plug is disconnected when you raise the tank, just reconnect it :laugh:
Not an expert
Latest Bikes
Forum statistics
Threads
177,961
Members
50,517
Latest member
pusparaj
