OB_KawAbuser
That is an awful lot of work and money to spend every 3000 miles.
The new strainer in the tank is supposed to have a larger mesh size than the original. Suzuki claimed the mesh size on the plastic strainers was too fine allowing gasoline additives to plug them.
There was a post (jeffw ?) here on this site a long time ago before Suzuki released an "Official" solution as per Bulletins 108 and 109. The early unofficial post stated the gas tanks were coated with a corrosion inhibitor that was not disolving properly.
The fuel pump filter is a pain to change, an ingenious GSX1300guy installed a inline filter between the petcock and the fuel pump.
He also removed the strainer from the petcock. It must be noted that he did these changes before the release of 108 and 109.
If you are seriousy considering the fuel filter change you may entertain the inline filter idea.
Keep in mind that Suzuki never changed the metal strainer in between the fuel pump and pressure regulator, I had ordered all the strainers and filters in the fuel pump prior to the 108 and 109 release. Check that strainer if you take apart your fuel pump, the part number has not been changed as the others were. I still wonder of it is a condition caused from the tank coating, as some people have posted problems after the 109 and 109 service's.
The strainer I mention to you is on the Suzuki micro fiche:
Pump Assembly
On the diagram page it is #26
Part #1516524F00 Screen, Fuel, Strainer
Pump Assembly
