@Mythos
Do not remove the clutch release cover...you called it a safety plate? to save weight.
The piston will move out of its bore while off,if somebody squeezes the lever with the cover off (it has happened to members) you wont like it. Why leave the cover hanging for a month? Take 2 minutes, put it back on.
When putting the cover back on,push the slave piston all the way back into its bore,then put the cover back on quickly making sure it is seated all the way around. Then tighten all of your bolts a little at a time in a cross hatch pattern like you would a cylinder head.
Check the fluid level in your master cylinder before pushing the slave piston home.If the level is a bit high pushing the piston back in could cause spilliage over the top. Members on here (and others I suppose) have cracked the cover trying to force the clutch actuation rod in by way of force on the cover bolts. No need to torque the krap outa the bolts either. Again,members have stripped the threads.
A clutch slave support bracket is a great mod.
GP shifting is not something I recommend even thou in theory it does force a harder shift from 1st to 2nd which we all know is a good thing on a lot of Suzuki transmissions. It takes some getting used and can actually be really fuggin dangerous...just my opinions on all that,
Rubb.
