Something you should consider. Going smaller on the front sprocket robs HP by wrapping the chain tighter. You can also develop problems with the chain rubbing the swing arm at the pivot point especially under power. This totally upsets your swingarm geometry.
If you want your bike to perform properly, you should take these issues into consideration when changing sprockets.
