SSGT_B
As most know I recently did new rotors, HH pads, new SS lines, RCS19 master and a deep cleaning on the calipers reusing the seals. No matter how much bleeding I did the brakes although slightly better, still felt lacking. So I ordered a new seal kit from brakemasters and decided since everything else was new, I’ll throw new seals at it too. Worse that can happen is the brakes still suck. Today I took them apart and found a few interesting tid bits. The pistons were not moving equally and they were a bear to get out. Had to use the air gun to pop one. A few seals were “tweaked”. After the new seals were in I used brake fluid to lube them and the pistons and the pistons slid back and forth like melted butter. After a good bleeding I have the lever tied off for the night. I’ll bleed them again tomorrow then hopefully off to test them.
