frame sliders need help
mynewride
i have lsl sliders and had to replace right side plastics. i need the measurements from lsl to get the center hole. it worked perfect the first time and id like to do it again except i lost the instructions.
thanks
ready, here you go per the printed instructions
1 mark the position on the fairing(dimensions shown in picture)
(1) upper fairing bolt; (2) bore; (3) axle, swingarm.
2 drill a small pilot hole (2) check the alignment to the mounting point. Then enlarge the hole until the fairing doesn't jam or scrub the spacer.
from 1 to 2 is 52 mm, from 3 to 2 is 495mm
hope this helps.
