kromdom said:running rich?
Its all stock. Whale does the pair valve do? It does look cool, but can't be good.
card16969 said:the pair valve takes air out of the air box and pumps it into the exhaust to reduce emissions it, is it a full system or slipons?
Slip ons
card16969 said:weird without looking at it and seeing it happen im not sure, have you hear any rough idle chugging sluggishness or anything before the exhaust?
Not really. If anything I thought it smelled rich. But the is just an assumption based on the smell of the exhaust
if it smelt rich it very likely could be.... could always put a good filter in it and take it in and have it ecu tuned, should run better
Yeah, if it smells rich, it's probably igniting in the exhaust - but not igniting till the end of the pipe when it gets some oxygen to support combustion. Pretty easy to know when a bike it running rich. Does the exhaust smell like gasoline? And is the outlet of your pipe sooty with carbon deposits?
Its marble mod timeSlip ons
chrisjp said:i put my full system high mount back in 06... pair valve and small air box mod... used basic high mount suggested map for power commander...always ran rich. lots of carbon in end of pipes... tuned last summer...MAJOR DIFFRENCE.. 18+ HP.... recommend asap
