do the jumper on the test wire to ground, it will give you a code one the dash.
gen2 is the red/white, black white, the two stacked wires on the outside. on the plug under the seat with a cap on it. you can search "how to to pull FI codes" and you will get some results.
once you have the code see which one it is, then go from there. probably a lose or missed connection
