I’ve been searching and searching and can’t find an answer... So I’m just gonna ask it. When extending the swingarm on an ABS Gen2, how to you go about extending the ABS line? Do the brake line manufacturers also make an extended ABS line?
Galfer can make you one to the length you want . There is a bracket inside on the frame that holds the line in place . It is just above the right foot peg , but below the seat. Its fun the obtain .
yes the brake line . if you want for shipping I could send you my old ABS sensors off my 2014 . they have same connector front/ rear . I'm sure you could use the front for the rear .
I have a question about the brake line. The kit I ordered came with banjo bolts on both sides but it doesn't match up with that's on the other end at the abs block
You received a incorrect kit or lines . Should be Banjo on master end and Flare on ABS block . Then flare again from AVS block to banjo for caliper connection .
Contact your seller about the issue .
