Munchie
My 09' silver gave me a one-time error last year while out on the road. I had stopped for gas, preparing to leave, and the bike wouldn't start...FI Light, but I had no idea what that meant at the time. Got off the bike, poked and prodded a little...didn't see anything obvious, and then - it started up fine. ??? Several months go by, and it happens again, but after working the key or rotating the bars, once again it started up. ??? ???
I'm not sure if its a wiring issue or a switch issue, but now it will not start. No amount of bar turning, harness tugging has helped, but I do know the code: C42. I also know that I am to look for a specific (100ohm) resistance between conductors in the ignition harness, but I can't find which pair of conductors to check between...and I've searched for a couple hours today. I see a ton of references to adding a resistor to work-around the problem (which I am fine with doing rather than replace the ignition/trunk lock), but again...I can not find the information to do it.
On the plug side, I have the following wire colors:
Red
Blue
Orange
Gray
Orange/Yellow tracer (stripe)
Brown
On the harness side, I have the following wire colors:
Red
Orange/Red tracer (stripe)
Orange
Orange/Green tracer (stripe)
Green/Black tracer (stripe)
Brown
Other than Heli-Bars, and an Acro exhaust, the bike is completely stock...no modifications or alterations. Can anyone tell me which of the conductors I should check across to verify the target resistance? lease:
Michael
Red
Blue
Orange
Gray
Brown
Red
Orange
Brown
Michael
