WisdomRacing
Hey guys. I've got a Busa powered (99-07) off-road race buggy.
The P.O. had run it without oil and decided not to tell me - first time out the engine seized.
Motor is now in pieces. The damage is a scorned crank, two rods and the channels on the case for the main bearings.
New (used) rods are on the way - still looking for a crank and case.
My question is, would the damage from a spun main bearing be economically repaired by a machine shop or would it make more sense to replace with a used case?
Another question; I've heard the 08-09 crank will work in the 99-07 engine and will yield some more displacement. True? If so would it be worth it (ie no additional cost other than pricier crank) to do this mod while it's apart?
I'm planning on my rebuild including the lower end along with a valve job. Anything else I should get into? I don't want too much power...the chain is sketchy enough as it is pushing this thing.
Some pics of the buggy:
Thanks for any help lease:
