Ok guys I have been having this problem for a while now and have a few questions that hopefully someone can shed some light on.
On decel at around 2500 RPM there is a noticeable rattle in the engine. It is not a main bearing rattle more high pitched and the valves are ok since I just check them when I repalced 2nd gear. I also checked the cam chain guides and the tensioner (which is new) and still I have a noise.
My question is, the cushion springs in the clutch basket, can those be making the noise? It will also make the noise if I set the high idle for cold startup, and after I ride the bike a while it will go away a little bit then come back.
any help would be greatly appreciated.
