Paintbawler
ok, I've just got this busa(this being my first post....not the way I wanted to have to intoduce myself). it's a 99 with power commander and full yoshi. all of the sudden friday it started jerking around while I was cruising. it was like the engine wasn't getting enough fuel or somethng. and then it just shut off. restarted the bike, let it idle for a little bit to see if I could find a problem with it, but didnt find anything, so I put it in gear and start riding, and it does it again. I went to the local shop and they said it sounded like a problem with the fuel system, he said to check everything from the fuel filter to the pump, to the power commander. well, I wanted to narrow that down, and so I searched on here, and found that someone had a similar problem and fixed it by cleaning their injectors. so here's my questions:
1. do you guys think that it's the injectors that are causing the problem? If not, what do you think could be causing the problem?
2. what do I use to clean the injectors? does it need to be a special cleaner, or can I use any injector cleaner? also, when cleaning, can I just run the cleaner through the bike, or do I have to pull the injectors to clean them?
again, thanks for the help in advance,
matthew
PS - NICE TO MEET EVERYONE
matthew
