Kiwi Rider
Well, a mystery transpired yesterday as I left home for a ride with my wing man Mark.
I started the ol'girl from cold and it ran ok and stalled after a few seconds, what?? This has never happened before!
Restarted it and put the 'choke/fast idle up to idle at 1800rpm, stuttered a little, then ran ok.
Warmed it up for a minute or so and put it in 1st gear.
As I released the clutch to leave and fed a little power into it, she suddenly misfired and ran on 3 cyls.
I thought to myself "If I just keep going it'll come back on song, but hmmmm . . . ".
I went up to 100kmh in 3rd but still on 3 cyls, suddenly it burst into life and took off with a full deck of cards.
Well that didn't last long, she intermittently went from 4cyls to 3cyl, back to 4, back to 3 and it appeared it was better if I brought the engine revs above 6k rpm.
This went on for a while, so eventually turned around and went home to investigate.
On the way home my brain was exploring all the possible causes and because of the nature of the misfire, instantaneous like a light switch, I figured it had to be electrical, a spark issue.
I suspected a faulty ignition coil, the spark plugs are near new.
If it was a fuel problem it would surge and the entire fuel system has been sorted recently anyway, yeah, it's gotta be spark.
Ok, so I got her into my surgery at home ( the garage lol) and raised the tank, removed the airbox, removed the coils one by one and figured I will spot the cylinder that has the misfire by the colour of the spark plug and then I'll test that cylinder's coil.
Well, as I took out No. 3 coil, lo and behold there's a few drops of water on the rubber seal at the tip of the coil.
Yip! Water!!! Ok, so that's gotta be the cause.
Dried it off and removed all the plugs and they're all the same colour. Phewwww!
I tested all the coils with my multi-meter and all checked out ok. Double Phewwwww!!
Re-assembled it all, started her up and she ran just fine.
Moral of the story . . . .
When you wash your bike, DO NOT spray water under pressure into the air vents in the side fairings!
When I thought back on it, yeah, I had just washed the bike and had sprayed water directly into the right hand side fairing without really thinking about it, I had washed it many times and NEVER had water in the plugs, after all, there is that big rubber cover that protects the coil/plug recesses in the cyl head and how would water ever make it's way in there??
Well it did, surprise surprise!
Anyone else out there ever had the same problem, just curious.
Story ends.
Story ends.
