Wrapping your exhaust pipes should never crack the pipe(s). Cracking is caused by extremely rapid cooling. Wrapping the exhaust should allow it to cool down even slower, thereby reducing the possibility of cracking. Try this sometime... turn on a light bulb and allow it to heat up a while... then unplug the lamp... (make sure you have safety goggles on) then place a cold towel on the bulb... metal reacts the same way to rapid cooling. Also for those of you with titanium exhausts, titanium cracks like a som-beech... especially thin titanium. Titanium is used on aircraft, not for resistance to cracking, but for resistance to heat. Thats why we use it for engine bay heat shields. Most of the newer fighter aircraft have even gotten away from using titanium components. They have gone more steadily to composites and aluminum alloys, except in engine bays. Even the more critical, high stress components are now made of steel and titanium alloys, rather than straight titanium. You may consider this before your next titanium exhaust system purchase. Also, I cannot imagine an exhaust wrap sold that is made from asbestos, esp with the federal rules and regs regarding asbestos abatement. However, if you do happen to purchase exhaust wrap that is made from asbestos, you probably should wear a proper respirator while cutting the stuff and proper gloves when handling it. Even some of the new asbestos "substitute" materials now-a-days are extremely carcinogenic when they are cut (fibres float into the air and get into your lungs). Do not breath the dust. The best thing to do is look on the package and find out what the stuff is made of. Then go on-line and see if you can find an MSDS (almost all MSDS's are avail on-line now). Download the MSDS, or view it, and read its description from front to back. It will tell you how to handle the materials.
